				ptitloup76
- Location:Seine-maritime[phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1275: count(): Parameter must be an array or an object that implements Countable
									by ptitloup76 » 04 Jun 2011, 12:19
			bien heureux de te voir revenu au guidon d'une NSR, mais décidément, que de déboires pour y arriver
- Location:34500 beziers herault[phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1275: count(): Parameter must be an array or an object that implements Countable
									by gdx666 » 04 Jun 2011, 12:48
- Location:saint mamet la salvetat 15220[phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1275: count(): Parameter must be an array or an object that implements Countable
									by krauthaker » 04 Jun 2011, 12:56
									by loulou88 » 04 Jun 2011, 12:58
			Laulau
J ai toujours dis,nsr un jour,nsr toujours....
				japan-power
				Angel
- Location:Mandres la Côte (Haute-Marne)[phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1275: count(): Parameter must be an array or an object that implements Countable
									by Angel » 04 Jun 2011, 14:22
									by krauthaker » 04 Jun 2011, 14:45
									by krauthaker » 04 Jun 2011, 15:58
									by gdx666 » 04 Jun 2011, 16:41
				old_mob
- Location:87[phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1275: count(): Parameter must be an array or an object that implements Countable
									by old_mob » 04 Jun 2011, 17:27
			C'est plutôt rare d'en trouvé en si bon état ! Tu nous donneras tes impressions par rapport au JC22
									by LeHautMarnais » 04 Jun 2011, 17:50
									by gdx666 » 04 Jun 2011, 17:58
- Location:Pierrefeu - Var (83)[phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1275: count(): Parameter must be an array or an object that implements Countable
									by Divi » 04 Jun 2011, 19:18
			Bien belle cette mémére !
				japan-power
				japan-power
									by mrbrikolage » 05 Jun 2011, 01:15
			belle bete, elle à l'air propre. pour le démontage c'est pas compliqué tu vire tout le carénage eh oui ça change du jc22
 mais bon avec l'habitude tu verras démontage du carénage en 10 min top chrono.
									by krauthaker » 05 Jun 2011, 10:11
- Location:AUXERRE[phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1275: count(): Parameter must be an array or an object that implements Countable
									by motom » 05 Jun 2011, 12:44
 Non mais dis donc CBRiste de Krau d'ou que t'as vus que s'était le bordel sur JC22????
En 10 mn on peut boire une mousse et fumer 3 clops mon pépère apres l'avoir dénudé
Felicitation mon Bicounet pour cette magnifique aquisition
J'aime bien cette couleur de JC20 mais je suppose que notre peintre fou va ressortir les pots de nacre.....
Attention les yeux!!!
									by krauthaker » 05 Jun 2011, 13:07
			bandes de jaloux
									by LeHautMarnais » 05 Jun 2011, 19:16
			commencement des vérifs.
J'ai viré tous les carénages et regardé un peu ce qui se passe là-dessous.
carburation en 132/52/70. j'ai déjà remplacé le GP par un 138. J'ai viré la fameuse bride à l'admission car elle était bien en place. TV78 opérationnel et cdi ci589c qui va bientôt se voir couper le pont.
A prévoir: changement des pièces défectueuses, toutes les ampoules en LED, bougie BR9EIX et réglage des valves.
Question aux possesseurs de JC20: on peut mettre des BA20D ? quelle est la position du starter quand celui-ci et en action ?
									by mrbrikolage » 05 Jun 2011, 19:48
			oui pour les ba20D.
position du starter au milieu de la fleche du comodo, il doit bouge au moins deux ou trois cm.
fais gaffe de pas trop monter en taille de gicleur car le JC20 est déja bien débridé et fonctionne tres bien avec les gicleurs d'origine.
									by krauthaker » 05 Jun 2011, 21:32
			wep exact millieu 3/4 gicleur 132/52/70 jai mis 142/42/65 avec pont du cdi couper et boite ouverte et cran sur 2 a l'aiguille
									by LeHautMarnais » 05 Jun 2011, 22:42
			ben disons que j'ai mi un GP de 138 car j'ai déjà viré la bride à l'admission mais pour l'instant aucune prépa. aie-je bien fait ou pas, à vous de me le dire car j'ai l'impression de retourner à mes débuts en NSR.
C'est une NSR mais c'est pas la même bécane.
